Any way to create a gradient blur? Top to the middle
dvip
Message par dvip »
Any way to create a gradient blur? :(
I would like to blur an image gradually from the top to the middle of the image (or from any side to the middle).
Re: Any way to create a gradient blur? Top to the middle
PhotoMasque has a Blur mode, try to use PhotoMasque with a custom gradient mask.
PhotoMasque on all versions, but only for gaussian blur.
Other way for PF7 : duplicate the part to blur, blur, and paste a gradient mask as alpha chanel in the new layer.
http://translate.google.fr/translate?hl ... e_PF7.html
For Studio you can directly apply a gradient from Layers menu.
You can uptdate your Profile to specify the version you are working.
dvip
Message par dvip »
Thanks guys!
I found out it can also be done with a plugin a lot faster.
I hope it can be done easier in the next PhotoFiltre 7.1. It is nice for adding a natural bokeh effect.
Picasa has a Soft Focus effect that almost does it but it isn't that precise.
==> no because it is already very with PhotoMasque, you not tested :wink:
Gradient blur is not the right way to do a natural bokeh. :wink: But if some plugin does it a lot faster, it's perfect.
dvip
Message par dvip »
Is there another way to make it look natural?
A very good specialist in retouching :
http://parengon.free.fr/pages/Ex07_Flouter.html
But with PhotoFiltre 7, to avoid halo around the clear subject,
it's possible to replace the clone stamp step by a selection expanded (more of 32 pixels),
which content is "Paste(d) in/Adjust size" in the original selection (expanded of 3 pixels), before to apply the gaussian blur.
And for the step to refine the hairs edges, you can try a duplicated layer of the clipped subject and turn the layer in Minimum blending mode,
or paint the floating hairs with clone stamp in Pattern mode on a Minimum blank transparent layer. :wink:
dvip
Message par dvip »
Thanks for the information, Tom.
