Cannot use the scanner
Message par 7 »
Hi,
just got the Photo filtre and I must say it´s a very impressive tool!
Unforunately the scanner (TWAIN, Mustec 12000) does not work :(
It starts scanning, but I get an askew (de côté?) picture. The corners of the picture are maybe 45 degrees instead of 90 degrees.
The scanner is older, but I use the latest driver version. Also I use the newest photo filtre. It´s running on a PII with win98se system and 192 MB RAM.
I like this program, especially the auto correction functions, but without the scanner...
PLEASE, is there anybody with a suggestion for me?
can you test with the twain plugin :
http://photofiltre.free.fr/tmp/TwainAcquire.zip
