How to save icon with transparency?
Postscripter
Mémoire RAM : 2GB
Message par Postscripter »
Subj. There are "export icon" menu item, but it works without any respect to image transparency...
Re: How to save icon with transparency?
Alpha transparency is not supported for the moment, only "simple" transparency
Postscripter
Mémoire RAM : 2GB
But how to paint "simple" (fully) transparent region for icon?
use Image > Transparent color and set the background color. After you can use the Eraser tool for example
But you have to switch the Image mode from RVBA to RVB. :wink:
Postscripter
Mémoire RAM : 2GB
Thank you!
domii
Message par domii »
Hello
What is the purpose of the Compression checkbox when I save to .pfi format?
Thanks
