how to make a fainter FOG effect?
kilele
Message par kilele »
Hello
I would like to know if there's a way to reduce the fog effect to achieve a faint effect as a way to add dust to a gradient.
Thanks
Re: how to make a fainter FOG effect?
Try the filter Reinforce (sharpen) with a radius 5-7 and Amout 50-70%
