remove the background of an image
gambiros
Version de PhotoFiltre : x
Système d'exploitation : win 7
Mémoire RAM : 4
Message par gambiros »
Buona sera,
there is a possibility to remove the background of an image?
Grazie
Gambiros
Re: remove the background of an image
you may use some selection tool and erase the inner or the outer part of the selection.
Look at the Documentation of PhotoFiltre Studio : http://www.photofiltre-studio.com/doc/index.htm
An automatic translation tool can help you even if the result is not perfect.
gambiros
Mémoire RAM : 4
merci.
Gambiros
