How to make PhotoFiltre the default photo viewer in Win XP?
				seeingblind
- Version de PhotoFiltre : 6.5.3
- Système d'exploitation : Win XP Pro SP3
- Processeur : Intel Core 2 1.83G
- Mémoire RAM : 3.25
I have not been able to find a Preferences setting to make PhotoFiltre my default viewer or editor in Windows XP? Am I overlooking something obvious? Thanks
Re: How to make PhotoFiltre the default photo viewer in Win
This property is a Windows one and can be adjust in Files Options from the Tools menu in Windows Explorer,
(in XP release) for any files with any applications.
Or a right clic on a file and chose "Open with", check "always open with" and chose the application.
But a plugin named Association can also be used.
To download from the official web site : http://www.photofiltre-studio.com/plugi ... ins-en.htm
				seeingblind
Great. Thanks very much for your help.
Ken
						Ken
