Specify a new path where save every time Photofiltre start
lamboman
Version de PhotoFiltre : 6.5.3
Système d'exploitation : XP Pro Sp3
Processeur : CoreDuo 2 T9300
Mémoire RAM : 3Gb
Message par lamboman »
Hi, i wrote from Italy and i've this problem:
My VB.net program before to start Photofiltre modify photofiltre.ini
Opening photofiltre.ini i see:
[Params]
Open=C:\...\JohnSmith\
Save=C:\...\JohnSmith\
These are the path where open and save images.
Then i acquire an image from scanner o from webcam
When i click on save button, photofiltre open the SaveDialogBox but the path where save is not the path specify in the [Params] but a path previously used.
Is a known problem or other.
Re: Specify a new path where save every time Photofiltre sta
windows 7 ?
Windows 7 ignore params path and use his own path. For the moment I don't know how to force windows 7 to use a path
lamboman
Mémoire RAM : 3Gb
Sorry, is my first topic and I have not specified that run on XP Pro Sp3.
Bye
in this case perhaps you have checked unique folder for opening and saving in the menu Tools > preferences > Folders
