New to forum and Photofiltre, Is there an tutorial on how to make selections, there one or two customs that I would like and thought what better way than learning.
appreciated
Making Selections
gordo52
- Version de PhotoFiltre : 9.2.2
- Processeur : amd
- Mémoire RAM : 2gig
Re: Making Selections
Hi and welcome,
i'm note sure if i had correctly understood the question but you can find more templates of selections
on the official site at the Add-ons page.
With a web translator you can also read the documentation for PhotoFiltre Studio.
Particularly you can draw your own selection form and save it by the menu Selection/ Save shape
The plugin "Contour to selection" allows you to create a vectorial selection from a black and white closed form.
You need to read the txt file which is within the plugin file.
gordo52
- Processeur : amd
Sorry I did explain it very well. Yea I wanted to create some selections for use with a special project I am soon to undertake.
I see exactly what you are saying. many thanks appreciated.
Fine ! you are lucky
i haven't understood from which selections you mean...
