Export layers
Export layers
Message par PHoto366256 »
How to export all 50 layers at once or I have to export layers one by one to PNG format?
Re: Export layers
Save image as pfi format.
Re: Export layers
Tom a écrit :Save image as pfi format.
I know that but I have to save all my 50 layers in PNG format. Photoshop have the ability to save many layers in PNG format from file - scripts - export layers to files but in Photofiltre I dont find anything like that. Only way I found is layer - export layer, where I can make PNG files one by one not together (at once).
Re: Export layers
An other roundabout way :
- on each layer : copy , right clic in the PFS workspace / Paste as new image.
- menu File / Close all
- when asked save the new images.
Or with the shortcuts : on each layer thumbnail : Alt + Y + X
Re: Export layers
Tom a écrit :An other roundabout way :
ok thanks,
I get it done
