With Classic Scheme turned on no Vista / 7 settings tab
Pac-Man
Message par Pac-Man »
Hi there,
the whole Windows 7 / Vista tab in the settings window disappears when I use the Classic Theme (not Aero or Basic) even though I am on Vista / 7.
This also causes the ugly old open and save file dialogs to be used at any time :(
Can you reproduce and fix this?
Greetings,
Pac-Man
Re: With Classic Scheme turned on no Vista / 7 settings tab
without theme you can not activate the gardient in tool bar or buttons, it is not possible.
It is for that the advanced display is disabled
Pac-Man
Ok, I don't really use the advanced design anyways.
What's nasty is that PF doesn't even use the new open / save dialogs with the classic theme. It always uses the old ones.
i understand but in my code source this function is linked with theme and i can not change it so simply
Pac-Man
Oh too sad :( But would be nice to see it working in the future.
