Comparison PF7 to PFSX, which Features are missing?
Pac-Man
Message par Pac-Man »
Hi there,
I recently saw you released PhotoFiltre 7, which looks very similar to PFS X for me. I didn't miss a feature I would've used in PFS X.
Will the feature set of this PF7 version remain? What features are exactly not included in PF7? A comparison table would be nice :)
Greetings,
Pac-Man
Re: Comparison PF7 to PFSX, which Features are missing?
it is in progress...
dvip
Message par dvip »
Pac-Man a écrit :Hi there,
Greetings,
Pac-Man
.8bf don't work?
There is a 8bf.pfl and a Raw.pfl.
yes, it is a bug with the first setup, i fixed it yesterday. PF7 don't support 8BF/Raw
Functions removed compared to PhotoFiltre Studio X
Animated Gif
Vectorial Path
PhotoPNG
RAW Format
8BF Filters
Tool Nozzles
Tool Deform
Tool Retouch (red eye, ...)
Advaced and Inverse Eraser
Border effects for layers
Pac-Man
This is awesome, my friends won't need the features which are removed.
On the other side you should also get their money.
I tell them to get PFSX :P
Automatic transparent gradients of the Layer menu aren't available in the 7 version, too.
It is possible to manage the transparency gradient with a mask pasted in the Alpha channel.
But for my own experience of photo retouching, it's a feature which greatly justifies to get the Studio release. :wink:
Pac-Man
Isn't plugin support "dangerous" at all in PF7? You could put in mostly all the missing features of the PFSX version.
dvip
Message par dvip »
I think PF7 should support 8BF, it can be used in Paint.net and Gimp
and we want PF7 to be better than Paint.Net :)
PF7 and 6.5.3 are excellent!
it is a suicide for the Studio version :wink:
