Good mornig
first of all, i'm sorry about my poor english, i studied it many years ago.
Now... my problem is that i' d like to scanner my color negative 35mm (kodak) and I'd like to trasform them in picture (positive) into the pc.
but the colors are false, not real.... I use the "negative" filter, ok, but I have to mask the base color of the film.... Is there a "set" to do that?
Thanks.....
Danilo&Silvia
Negative 35mm
DaniloSilvia
- Système d'exploitation : vista Home
- Mémoire RAM : 2GB
Re: Negative 35mm
Hi,
to scan a negative fim or a diapositive, you need a special scanner which can read an exposed light through the film and not by reflection.
I don't believe that any soft can get you a correct result without a special scanner.
DaniloSilvia
- Mémoire RAM : 2GB
Re: Negative 35mm
thank you....and I'm sorry about a lot of time I have spent before I write this thanksTom a écrit :Hi,
By
DaniloSilvia
Re: Negative 35mm
No problem
Thanks to say hello.
