Edge Filter_quick art!
Jaume44
Système d'exploitation : w7
Message par Jaume44 »
In PF under filters, the filter, Edges, is found. Below is a sampling of just how it may help anyone in producing an artful finish on an otherwise plain photograph or image with the three edge options depicted along with the original image.
Uploaded with ImageShack.us
Re: Edge Filter_quick art!
Fine work Jack . :clap:
A realy artistic result. :)
