Bug with massive drag-and-drop
Postscripter
Mémoire RAM : 2GB
Message par Postscripter »
Trying to drag 37 BMP files to PhotoFiltre window, I get only 20 files opened. The remaining files are ignored.
"20" is a constant number. So, if I want to edit 999 photos, I have to break it to portions, of 20 files each, and then drag them one at a time.
Bug or dubious future? :)
PF 6.5
Re: Bug with massive drag-and-drop
yes the limite is 20, it is not a bug it is a limitation for memory :wink:
Postscripter
Mémoire RAM : 2GB
Which limitation? I have 2GB and I sure - it's more than enough... Or not?
the problem is not image count but image size and undeo/redo memory used.
Don't know what you with lot of image but perhaps automate is better....
Postscripter
Mémoire RAM : 2GB
Automate does not work correct. Take a look at this topic: viewtopic.php?f=15&t=19388
I would be grateful if you fix it...
