Hi,
I've been searching for a way of somehow improving the quality of small pictures, i.e. something that one might copy from his screen. My reason for doing this is so that I can blow it up, without loosing too much definition, and it seem like increasing the picture size does the job. For example I took a picture 958x512 and increased it to 3832x2048. This allowed me to blow it up significantly before loosing too much definition.
I have two questions.
1) Will this method result in better clarity when the picture is blown up, as in for a slide presentation?
2) Is there a better way of doing what I'm trying to do?
Thanks,
...... john
improving picture quality
Shinnen
- Mémoire RAM : 1.5 gig
Re: improving picture quality
when you increase the image you can change the ressemple filter, try some filters for test the result because it can be differente for each photo
Shinnen
Hi Antonio,
Where do I find these filters? I'm using Photofiltre 6.5.2.
Thanks.
..... john
Thanks.
..... john
sorry, only in the studio version for the moment
Shinnen
Thanks.
...... john
...... john
