Ambiguity with converting to PNG
Postscripter
Mémoire RAM : 2GB
Message par Postscripter »
Hello.
I use PhotoFiltre 6.2.7 and 6.5.2. There is a serious bug with "automatization" tool. Take a look at this two PNG (in attachments) - first converted manualy from original BMP, and second - with use of "Automatization" function. Both of them have similar color space - 16 colors. But first weighs only 60 kb, while second - at least 122 kb !
What's wrong?
Dernière modification par Postscripter le 11 nov. 2011 20:25, modifié 3 fois.
Postscripter
Mémoire RAM : 2GB
Re: Ambiguity with converting to PNG
I think it is not a bug but perhaps your base image is in 256 colors ?
When you use the automate, it force image in 16M for filters and when you save the file is bigger.
In the automate, you must force the color count to 256 to reduce the file size. Of course if all your base images are in 256 colors max... :wink:
Postscripter
Mémoire RAM : 2GB
I tested it with different pictures - the same result. For example look at the properties of presented "Test" images:
Manual:
Code : Tout sélectionner
Proprietes de l'image
Nom de l'image : Test manual.png
Dossier : C:\Documents and Settings\Саша\Рабочий стол\
Dimensions : 500 x 500 pixels ==> 13,23 x 13,23 cm  (96,00 dpi)
Nombre de couleurs : 15
Taille du fichier : 59,63 Ko
Date : 13.11.2011 12:23:46
Auto:
Nom de l'image : Test auto.png
Nombre de couleurs : 16
Taille du fichier : 122,73 Ko
Date : 13.11.2011 12:23:48
Current job - reducing weights of some scanned images. Original images have 16 colors, but are presented in BMP.
Manual: opening, converting to RGB (as you said), converting to 16 colors, saving to PNG. Result - 147kb. File properties: "4-bit color image"
Auto: converting to 16 colors, saving as PNG. Result - 3,8 MB. File properties: "4-bit color image"
It looks like a bug, smells like a bug... So... It's a bug.
Postscripter
Mémoire RAM : 2GB
Are you here, Antonio? What can you say?
i will test this week with your image...
Postscripter
Mémoire RAM : 2GB
Thanks!
I tested, it is not a bug but i use a default compression level = 7 for direct save function and Compression level = 0 in the batch module.
I will set compression level = 9 (best size) for both in the next version :wink:
Postscripter
Mémoire RAM : 2GB
Thank you. It will be very, very helpful! :) But will it affect quality?
Dernière modification par Postscripter le 22 nov. 2011 14:54, modifié 1 fois.
no, png don't affect quality only time for compression
Postscripter
Mémoire RAM : 2GB
Postscripter
Mémoire RAM : 2GB
Hi, Antonio! It seems you forgot about me...?
I tried 6.5.3 Image
Postscripter
Mémoire RAM : 2GB
fixed for PhotFiltre 7 and for next studio version
Postscripter
Mémoire RAM : 2GB
But what about "users which remain allergic to layers"?
