Is there an image size limit? How do I alter it?
jntm
Message par jntm »
If I read a reasonably large scanned image into PhotoFiltre (e.g. 1500 x 1000 pixels @ resolution of 300 pixels) all items in the Adjust menu (and lower command bar) are greyed out.
If I copy the image and 'Paste as new image' Adjust will now work, but resolution has been reduced to 72 pixels. Likewise if I markedly reduce the image size, Adjust begins to work (though I may have to save, close and reload the image).
Is there some image size limit? How do I find out what it is and/or manage it?
Thank you for your help!
John M
Re: Is there an image size limit? How do I alter it?
After the scan, force your image in RGB mode (menu Image > Mode)
Hi,
the updated release is 6.5.2 on this page : http://photofiltre.free.fr/
I think it's solve your problem of color mode. :)
