Antialias option does not work
waniaa
Message par waniaa »
Since version 10 does not work for me antialias option. Why. Whether it is the fault of the program.
Re: Antialias option does not work
I don't know if we speak about the same function, but for me it gives that :
The function options are available in menu Selection/Antialiasing or in the right click in a selection / Antialiasing
and the shape of the selection is filled by Stroke and fill function but only "fill" checked.
yes, what antialias function ? :wink:
