plugin bar shows only about half of pluggins
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
My plugin bar only shows about half of the ones installed (PP_II_EN.exe). I have them all checked off in preferences. Does anyone know why?
Thanks,
.... john
Re: plugin bar shows only about half of pluggins
Hi Shinnen
you have reach the limit of 20. Effectively PF doesn't display all the plugins.
Shinnen
Hi Tom,
OK ..... thanks. I thought I might be doing something wrong. So ...... can I choose the 20 that I use most often, to show?
Thanks,
..... john
