viewing directories
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
viewing directories
Message par Shinnen »
Hi,
Is there a ways of viewing directories, as thumbnails, then expanding the picture that one wants to edit?
Thanks,
.... john
Re: viewing directories
Hi,
:shock: menu Tools / Image explorer does'nt match ???
Shinnen
Hi Tom,
Thanks for replying. Yes.... that works, but can I get Photofiltre to open at a specific directory, with the thumbnails at the bottom, every time I open it?
..... john
Yes and no... (my grandfather was Norman :) )
PhotoFiltre is not built to open directly the Image explorer.
But it keeps, in the ini file, the path of the last folder opened, so i suppose it's a problem when calling the image explorer/explore/a folder,
I think it would expand the correct path and highlight the correct folder, and i haven't succeed.
I will tell that to Antonio for the next releases.
Edit : Antonio give us a tip : menu Tools / Image explorer and press the F5 key :shock: :D 8)
Shinnen
Hi Tom,
Thanks again. If I press F5 after Photofiltre opens I get the icons of my pictures. This is great (most of the time) but sometime I want to change folders, which means going to the menu and choosing another folder. But the F5 will work, and your suggestions helped me to get what I want. I've seen some other apps that open at the last folder, with the folder list down the side of the page. That would be ideal. But they don't have the functionality of Photofiltre.
... john
Have a look in the Preferences/Folders. You can also define the behaviour of PF6 to open and save. :wink:
Shinnen
Thanks again Tom,
I have looked at the preferences, but I'll take another gander.
..... john
