Image Size/Fit Image
APG
Whtat's the difference between Image Size and Fit Image? Because when I chahge the size of the image both options do the same.
Re: Image Size/Fit Image
Hello,
the image both options do almost the same, yes,
But... in Fit Image the limits values are maxi values, so you can fit for example 800 pixels both for width and height,
and you can forget if your image is in landscape or portrait orientation, the result will anyway be correct.
It's clever, no ? for the web, forum, or mailing ...
