PF 6.1.1--Full Screen loses Selection
echo0001
Version de PhotoFiltre : 6.1
Système d'exploitation : Windows 98
Mémoire RAM : 64mb
Message par echo0001 »
Hello,
I just downloaded 6.1.1.
Previously, with other versions, when I wished to check the placement of a selction or text--BEFORE validating the selection\text--I could press Control+F to check my image Full Screen. I could then click the left mouse button and return to PF, and my selection was still unvalidated, allowing me to continue moving the selection if necessary.
With 6.1.1, this does not seem to work anymore. When I pressed Control+F to check my placement full screen, and clicked the mouse to return to PF, the selection\text had become validated, whether I was finished moving the selection or not.
I hope this not intended. Being able to check placement Full Screen, and then being able continue to manipulate the selection is one of the features I have come to use and enjoy the most. It is especially useful with larger images.
Can, and will, this function be returned to PhotoFiltre?
Yes it's bug ! This bug was not indicated during the test periode :cry:
And the next release is only for jun or after, It is pity.
echo0001
Mémoire RAM : 64mb
I did not think it was intended. It's really too bad about this little bug....
But I still have the installer for 6.0.2! :D I can alway make that version available again, in another directory if necessary.
Thank you for your fast reply! :shock:
Try with today release (6.1.1) :wink:
echo0001
Mémoire RAM : 64mb
:shock: WOW! That was FAST! :!:
And very very much appreciated!
Thank you for the fix!
