Hi,
I'm using version 6.5.2
Often I take photographs of jewellery, which can be very difficult to do without leaving shadows, usually on the background. Is there a way of removing these, while maintaining the same 'texture' as the surrounding areas. Right now, I fill in the entire background with a uniform colour, which is often bland, and usually results in loss of detail at the interface of the background and the item being photographed.
Thanks,
.... john
removing shadows
Shinnen
- Mémoire RAM : 1.5 gig
Re: removing shadows
Hi Shinnen,
i am not able to purpose a correct process without an example.
Any way you have to do a clipping, but several methods are available, depending of characteristics of the background.
Shinnen
Thanks Tom,
..... john
..... john
