How 2 disable transparency i.t. Setting-box, Properties etc?
come2ghost
Version de PhotoFiltre : v6, v7
Système d'exploitation : W11
Processeur : i5-8XXX
Mémoire RAM : 8GB
Message par come2ghost »
i don't like the transparency in the boxes, it's irritating me.
Is there any way to disable this?
Re: How 2 disable transparency i.t. Setting-box, Properties
Good afternoon, :)
perhaps is it an other way to set a question ?
Is there any way to disable this irritating behaviour ?
read you soon with pleasure in an other mood. :wink:
come2ghost
Mémoire RAM : 8GB
sorry, my english is not good enough :oops:
thanks for correction.
All right, gameover, we begin a new set. :)
I think you are using the Studio release : look in the menu Tools / Preferences : thumb Startup
and you can unchek "Alpha-blend dialog boxes" but you need to restart PhotoFiltre.
Enjoy with PhotoFiltre, it will amaze you more and more.
And if not, tell us what happends, perhaps can we help to find an other way to do. ;)
come2ghost
Mémoire RAM : 8GB
That was the setting i was looking for.
Now the dialog boxes are even better.
Thank you very much Tom!
