i'm using photofiltre for 2+ years and i would like you to think about adding a very useful options to polygon selection.
first one is an undo.
i really wish a selection undo stack, but after 50+ polygon selection points, i could live by undoing only the last one...
to avoid recoding, you could add a "shift-esc" or "ctrl-esc" or "alt-esc" combination (whatever fits best with your keying standards) to your selection keypress case,
to remove the last selection point.
second is allowing zoom while selecting a polygon.
most of times i need a big zoom to select, but then i lost myself in a bunch of pixels...
i mean, sometimes i need to see the "forest", other the "tree"... or worst, the "leaf"
as i've to use vertical and horizontal bars a lot because a big zoom, it's very easy to click inside the picture instead the bar, messing selection... and after many points, you can imagine my "lyrics"...
anyway, thanks.
kutgw, you really have a very good piece of software here.
cesar.
