Studio - thinking of upgrading
user41
Version de PhotoFiltre : 10.4
Système d'exploitation : 7 64bit
Mémoire RAM : 4GB
Message par user41 »
I have been using the trial of PhotoFiltre Studio for a few days and have a few Questions.
No Copy/Paste when in the image size dialogue box
Not able to move text in a layer unless using the curser keys
These were easily done in Photofiltre - but not the paid for version of Studio :?:
user41
Mémoire RAM : 4GB
Re: Studio - thinking of upgrading
Ok, managed to move the Text now, I was inadvertently clicking on a lower layer when trying to move it.
Still not being able to copy and paste when changing image size, is enough to keep me using the free version to be honest.
For any major work I bring out PShop, so Photofiltre is really just for the little quick edits, like image size,
so not supporting a simple copy or paste in the image size box, is very limiting. :(
It is possible to copy/past with the mouse (right clic) but not with the shortkey CTRL+C/V
user41
Mémoire RAM : 4GB
Antonio a écrit :It is possible to copy/past with the mouse (right clic)
No It's not. Paste does not work With the right click or Ctr+v
Antonio a écrit : but not with the shortkey CTRL+C/V
Wrong again I'm afraid, Copy does actually work with CTR+C and/or right click menu.
The only way I found Copy was working, was pasting into notepad, As nothing will PASTE into your dialogue box's
Tried running the program as Admin, and in compatibility mode, none worked, looks like "no paste" is a feature of the paid for version, and not a nice one :(
Yes it's right : the right clic to paste doesn't work :|
But in the same time it's not a tragedy :!: you don't think so ? :roll:
ok i see the bug, it is only in this last version, i will fix it in the next...
user41
Mémoire RAM : 4GB
Will look forward to a fix, thanks for looking into this Antonio :clap:
While not a tragedy , as Tom says, its something I use all the time, so would stop me upgrading to paid...
