Hi,
Is there an unmask sharp function in 6.5.2? I can't find one.
If not, is there a way of adding it?
Thanks,
..... john
umask sharp
Shinnen
- Mémoire RAM : 1.5 gig
Re: umask sharp
Hi, Shinnen,
i think you had better to search with unsharpen mask in the research tool.
Antonio has already answered for this existing tool with an other name.
You can also simulate a "high pass filter" with a formula in the Arithmetic plugin :
by following the process for Studio release : http://translate.google.com/translate?h ... p?p=158317
which can be done with the Arithmetic plugin in the PF6 release :
http://translate.google.com/translate?h ... 38#p160438
Shinnen
Re: umask sharp
Hi Tom,
I found a little tool called 'Sharpcontrol'. It seems to do what I want fairly well.
Thanks again for your help.
.... john
.... john
