This is one of my most used programs. Love it. For example...
I have a number (about 25) of town maps (JPG's) that I color the property lots to make the map more "readable" on the town web site. I have about 8-10 different colors so each lot does not have the same color as abutting lots.
Is there a way to "save" the custom color "palette" so it can be used in other files? Currently I have to "redefine" the 8-10 colors for each file (hue, sat, lum, & RGB values).
Thanks
Jim T.
Save custom colors
Re: Save custom colors
Hi,
no, there is no specific way to save colors, but i can suggest you a tip :
You can create your own palette and save it as a png file. (file format which keep the true color)
Each time you need it, you open this own palette and chose the whished color with the pipette tool
If the image is cross-ruled it's more easy to select a square and fill it with a new color.
You can also use a raw to tag a letter to name the serial column...
I hope it can help you.
