Zoom tool in PF
ithilion
Zoom tool in PF
Message par ithilion »
Thanks a lot for an excellent graphical editor! As for me, there is just a tiny list of disadvantages in PhotoFiltre, and the first is this:
Zoom tool.
Are you going to make a text field to type the exact zoom in percents instead of a fixed list? Of course, if I really need some special zoom I can select 'Auto' and adjust the window borders, but that's annoying.
P.S. Sorry if it was already discussed, I've got great problems with French:(
Re: Zoom tool in PF
Hi,
yes this question was discussed a long time ago. :)
Don't forget that you can use the wheel of the mouse to quickly scroll the zoom factor.
Any way, there is very few need to view other zoom factors because they take time and processor resources
for a tiny result because the only real view of precise quality is the real size of the image.
All the other views are refined with an antialiasing process or interpolations .
Re: Zoom tool in PF
it is right,n i don't understand the need of an exact zoom factor ?
