Chien, Yorkshire Terrier
Jaume44
Système d'exploitation : w7
Message par Jaume44 »
My beloved sister sent me a photo of her Yorkie. The photo has been processed in PFS 10 by layering the image on the colored background, then executing a radial transparency on the image. After merging the background with the radially tranparenticized layer, the No. 12 mask was applied in the color viewed, then the image of the puppy only was captured using the lasso and leaving the border out of the capture. Next the capture was reversed and the applied mask was enhanced utilizing the engraving tool with the color engraving option. Last of all the same area captured of the mask was enhanced even more by clicking on the sharpen icon until the desired effect was achieved. That would be the lesser sharpening option. I like the results; I hope you do also.................jack PS, I also applied a frame................but that is totally optional.
Uploaded with ImageShack.us
Re: Chien, Yorkshire Terrier
Hi Jack,
fine shot and good work of perspective. The shadow gives a real depth of view on a soft engraved background.
I think it was too a long work of clipping and cut off.
Thanks to share the method and the picture of this nice puppy.
Jaume44
Thank you, Tom. I always love your informative feedback, and I try to keep what you say in mind for anything attempted.
Merci, vous êtes toujours aimable!
Good job indeed.
Ca c'est vrai ça ! You're right, Tom has always good advices.
Like Snoopy : "You know what ? - I'm happy - It's too much - I'm pink of embarrassment" :oops: :wink:
Pardon Tom, You know what ? I'm happy c'est de Drooppy non ? :wink:
Arf ! :roll: j'en mélange mes classiques. You are right my dear Watson.
Message par Coraliecaramel »
Bonjour Jack,
Superbe toutou.Il viendrait bien jouer avec Binnie. :clap:
Jaume44
Alors, il est trop grand, mais trés beau, merci!
arianne
Version de PhotoFiltre : PFS 9.2.2
Système d'exploitation : 32 bits service pack2
Processeur : IntelR Quad 2.40 GHz
Mémoire RAM : 2.00 Go
Message par arianne »
:clap: Le York est magnifique :clap:
