PF free freezes
chicchio
Version de PhotoFiltre : 7.0.1
Système d'exploitation : xp pro sp3
PF free freezes
Message par chicchio »
Hi to all !
I am new to this forum.
Running XP pro SP3 and PF free 6.5.2
PF freezes when I perform these actions:
Selection > Ellipse > I select a part of a JPG
Then: Edit > Transform > Distort
PF performs the distortions, but freezes on that operation, I cannot do anything else, neither close the program (I need to shut it down by Task Manager).
Any fix ?
Thanks, Chicchio
Re: PF free freezes
PF is not stable with some windows XP version, don't know why :cry:
(if the problem is PF or somme XP dll)
