What program was used?
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
At one time I made a fractal image of a picture that I took.
I don't think it was Photofiltre, because I can't see any way of
making fractals with it.
So..... is there a way of telling what program was used to edit
and image?
Thanks,
..... john
Re: What program was used?
Here is only a PhotoFiltre forum :wink:
Shinnen
Hi Antonio,
Yes... that's what I thought.
.... john
But you can find some 8BF plugin to create fractals, don't remember the name :roll:
Jaume44
Système d'exploitation : w7
Message par Jaume44 »
If you are using PhotoFiltre Studio, you may use any 8bf plugin with the fractal option. Richard Rosenman's "Fractus" will do it.
Taobert
Version de PhotoFiltre : Studio 10.10.1
Système d'exploitation : Linux - Lubuntu 14.04
Processeur : Intel Celeron 2,66GHz
Mémoire RAM : 1,24 Go
Message par Taobert »
There is one here but it's not free.
Or see here too
8)
Shinnen
Hi,
I eventually found out that Gimp's 'Fractal Trace' will do this.
It gives some very interesting images.
Thanks for your help.
.... john
Postscripter
Mémoire RAM : 2GB
Message par Postscripter »
is there a way of telling what program was used?
There must be some info about creator in EXIF
