Additional Tool Suggestion.
elle
The transparency function in Photofiltre is excellent and probably the best I've come across..However I found the lack of an erasing tool frustrating. The image being worked on had a multi-color background and the image background itself required a new color fill. I used the lasso and magic wand as much as feasible but the background was left with orphan pixels scattered across the large background. Ordinarily I would apply the eraser tool to clear them so the entire area could be filled with the photobucket which would have been so much more efficient than the paintbrush in this instance.
Re: Additional Tool Suggestion.
with simlple transparent color, it esay to use unique color for background but with alpha chanel it is not so easy because you can have progressif contour or partial transparency. in this case you must preserve original background color.
