Does anyone know that this software change background of photo ? if yes how.
Thank you
Changing Background of photo
Re: Changing Background of photo
Hi, just above your message, in the" rules of the forum" you can find some links towards the offical sites of PhotoFiltre and PhotoFiltre Studio.
Particularly on this page you have several tutorials to answer your question : http://photofiltre.free.fr/tutorials_en.htm
But you can notice that the software doesn't change anything without intended action of the user.
Here you have to select the part to be copied and pasted on an other background. Have a look to the menu Edit/Optmized clipping.
With the Studio release wich can works by layers you have several ways to proceed and put an other background
under the original.
under the original.
