photofiltre freeze
gvp
photofiltre freeze
Message par gvp »
win7x64 sp1
latest photofiltre version 6.5.2
hp scanjet 4670
the program works great but when i press the cancel button in my scanner gui form the program freeze.
it's not something important but if you can do something about that i would be grateful ...
thanks for your very useful program.
Re: photofiltre freeze
PhotoFiltre is bugged with some scanner model :cry: (if they are not 100% twain compatibe)
No solution finded for the momemnt
