Putting Text Around A Circle
below2doe
Message par below2doe »
Hi All,
I have the free down load of Photo Filtre and was just wondering can you put text around a circle by typing in the words then wraping it around the circle. Or do you have to put each letter with - and + angle. Hope some one can help.
Below2doe.
Re: Putting Text Around A Circle
Hi,
with the research tool and text +circle as key words you have 6 answers for two issues.
search.php?keywords=text+%2Bcircle&term ... Rechercher
You need to download a plugin from the official site of PhotoFiltre.
"Paste into", or "Text to Path"
You can also read the txt file within the plugin to understand how it can work.
But you have to think that a such process distort the curves of the characters.
So you have a better result by working on a double size and reduce when completed and apply a light sharpen filter.
