If I can add text to images in UNICODE(UTF-8) using pfs10
garvtul
- Mémoire RAM : 2gb
Re: If I can add text to images in UNICODE(UTF-8) using pfs1
no, unicode is not supported by Delphi 7
garvtul
- Mémoire RAM : 2gb
But you know that UNICODE is the need of the Day !
Something must be done for it.
dmitri
- Version de PhotoFiltre : 6.5.2
- Mémoire RAM : 3GB
I quite agree. I cannot open files with non-Latin names in the file pathgarvtul a écrit :... UNICODE is the need of the Day !
(And it's strange, given that the product is not made in USA)
dmitri
- Mémoire RAM : 3GB
I would think that the problem stems from lack of a requirement, not just from a wrong choice of a tool.Antonio a écrit :no, unicode is not supported by Delphi 7
Even with Delphi 7, one can use wide string class, and controls from TNT library for Unicode-enabled UI. Yes, it needs some effort, sure.
Upgrading to Delphi 2010 (or maybe porting to Delphi.NET) might help as well.
Really...
==> of course but last Delphi version are not very stable, Delphi 7 is the best version for the moment
with TNT library, i need to change all my text component, not the best solution. It is a good library for new code, not for portable code
