Hello
I opened file, then selected FILE - Print and got a message
Le format '%.2' est incorrect ou incompatible avec l'argument.
When I press OK, I get the Print window, but If I try to move scale pointer, then I get tens of same messages
Both 6.1 and 6.1.1
Win XP SP2
Russian version of Photofiltre
Thank you
Problem printing
- Membre d'honneur
X25
