Feature Request - Automate / Batch
aychekay
Message par aychekay »
I use the Automate / Batch feature a lot. Here's some things that would make this tool much better to use:
1) Button to fill in Output Folder with A) a default folder setting or B) same as source folder
2) More sequence options. I'd like the ability to append things to the beginning or ending of the existing file names.
3) Option to "not enlarge file if smaller than selected width/height"
