What happens after 30 days of usage?
Will Photofiltre Studio features reduced (which ?) or will it stop working completely?
What are the differences between Studio and Free Version?
Is there a side-by-side comparison table?
Peter
What happens after 30 days? Comparison of Free vs. Studio?
pstein
Re: What happens after 30 days? Comparison of Free vs. Studi
the software lock and you can not use it, you must remove
here is the difference between PF6 and studio :
http://www.photofiltre-studio.com/present-en.htm
all functions presented are only in the studio version
