Susie
Messages : 2 Inscription : 09 déc. 2010 17:07
Version de PhotoFiltre : ?
Système d'exploitation : Windows
Processeur : Celeron
Mémoire RAM : ?
Message
par Susie » 09 déc. 2010 17:13
Although I know the typed shortcut for the copyright sign in Word, it will not work when I type text on a photograph.
All I want to do is add a small "(Copyright) Susie" on the bottom of certain photographs. Can anyone tell me how to get that c within the circle on a photograph?
Messages : 13308 Inscription : 02 févr. 2005 9:35
Message
par Tom » 09 déc. 2010 19:29
Yes the shortcuts does'nt match in the text module.
But you can copy the sign and paste it in the text module with the same choice of font.
If you have a keyboard with a numeric keys bloc, you can try Alt + 184
Susie
Mémoire RAM : ?
Message
par Susie » 11 déc. 2010 11:16
Thank you, Tom! Will first try your shortcut suggestion.
If that does not work, I'll try copy-and-paste! I never thought of that!
Susie (with about 1,000 more questions ... but that will wait).
Messages : 13043 Inscription : 28 oct. 2003 22:49
Message
par Antonio » 11 déc. 2010 12:34
use the char tab to insert special characters (is for that i added the button in the text module
Message
par Tom » 11 déc. 2010 17:08
Sorry Antonio, but the char tab is only in the Studio release of PhotoFiltre, not in the freeware.
Message
par Antonio » 11 déc. 2010 19:01
oups
