Text is not compatible with IME (Japanese)
masuda
Version de PhotoFiltre : 6.5
Système d'exploitation : Windows 7 (64-bit)
Processeur : intel i5
Mémoire RAM : 6G
Message par masuda »
Hello,
Recently I got new PC with Windows7 (64-Bit) using Microsoft IME for Japanese Text. I installed PhotoFiltre version 6.5.0 and start using it, and I realized Japanese text conversion stopped working in PhotoFiltre.
I was using Japanese text last 5 years in PhotoFiltre without any problem with Windows XP.
Thanks,
Satoshi
Re: Text is not compatible with IME (Japanese)
Text using unicod 16 bit is not supported :cry:
