Function Fit Image
kiwichick
- Version de PhotoFiltre : PhotoFiltre 6.4.0
- Système d'exploitation : Windows 7 Home Premium 64-bit
Function Fit Image
Hi there, Can someone please tell me what the Function Fit Image preference is for? Thanks.
Re: Function Fit Image
Hi,
did you tried it on a copy ? and what happends ?
kiwichick
Hi there, Thanks for that but it doesn't really help. How would I have used it on a copy when I have no idea what it is or what it does? I have no idea what you're talking about.
Precisely, if you do a copy, you can apply any function without dammage to the original picture.
Try and see is sometimes a way to understand.
Otherwise the user manual for Studio version can help too. It is available in the Tutorial section : viewforum.php?f=22
on this topic : viewtopic.php?f=22&t=10808
which links to the directory : http://translate.google.com/translate?h ... /index.htm
See particularly : Image size and cropping
