Scanning problems
daria19
Re: Scanning problems
Message par daria19 »
Hello,
daria19 a écrit :
I have a good quality scanner..., but I have a lot of scanning problems...
So please give me any suggestion...
Please Help me. :(
1) did you selected your scanner using the menu File > Import twain > select source ?
2) what is the error message ?
larry34
Message par larry34 »
Hello guys'
Could anyone tell me? How to fix if my HP Scanner is not working or showing scan connection error using HP Print and Scan Doctor Diagnostic Utility for Windows?
When you try to use your scanner from the PhotoFiltre application, you think your work as a pull action,
intend to get back the image from the scan. Ok it doesn't work as expected... :(
But you can think your work as a push action : most of scanner models have a specific sofware program which can push the result :
- some of them can transmit (or pass hand) the image result to an image-editor application, perhaps PhotoFiltre.
You have to look into the settings of the scanner software if this option does exist.
- and most of them can automatically save the image result in a folder defined in the settings. So you can also scan your images by lot,
may be in PNG or Tiff format (lost-less).
and of course you can open this folder and double clic these images to open them (push again) with PhotoFiltre
(if associated in Windows settings to this file format).
danish34
Message par danish34 »
Hello, guys
My Scanner not working is a common issue in Windows, especially in new Windows 10 :|
Any suggestion :?:
perhaps missing twain drivers ?
