Restore images last position
cbr
Version de PhotoFiltre : 6.5.0
Système d'exploitation : Windows Vista/7
Processeur : Intel Core 2 Duo
Mémoire RAM : 4GB
Message par cbr »
Hello,
Is there any way to make Photofiltre reopen the image windows in their last position and size?
I work with several images open at the same time using different sizes and positions and every time I close the program I have to reopen and reposition each image manually.
If save/restore is not possible, I leave it as suggestion for a new feature. It would be very helpful for me.
Thanks!
Re: Restore images last position
for the moment it is not possible :cry:
