W&B images
bebbetto
Processeur : Intel centrino 2
Mémoire RAM : 2 G
W&B images
Message par bebbetto »
My photofiltre version is a freeware 6.4.0.
With the W&B photos, some buttons (sharpen, contrast, gamma ... ) are disabled. Why ?
Must I upgrade to the latest version ?
Thanks
Bebbetto posting.php?mode=post&f=2&sid=2f87256a2 ... 64135df1bd#
Re: W&B images
Hi
you can click on the ? menu / Information, and look at the first item :
Availability of filters and menus
The filters in certain menus are available only in 16 million colors without the transparency option
because most of them recompute and modify the colors. For example, they are disabled for GIF
images and images in indexed colors mode. If you do not have access to these menu item filters,
perform the following operations:
• Select the menu item "Image / Transparent color" (in situation of an image with a transparent color)
then click on the option "Disable transparency"
• Select the menu item "Image / Mode / RGB color"
bebbetto
Mémoire RAM : 2 G
Re: W&B images
Great !! It works.
Thanks a lot
bebbetto
