PhotoFiltre 6.5.0 with Windows 7 64 bit
leontb
- Version de PhotoFiltre : 6.5.0
- Système d'exploitation : Windows 7 64 bit
- Processeur : Intel
- Mémoire RAM : 1 GB
Hi people,
my new computer came with Windows 7 installed on it. Of course I wanted to use PhotoFiltre again so I installed the latest version.
Now, I have two problems:
1. When I want round corners of images, the corners are much bigger than when I used Pf with Win XP.
2. The great feature 'automatic crop' delivered in XP a popup window with an image in the correct width/height. In Windows 7, the images goes to rightunder and you have to cut it (from the background) manually. Any ideas? Thanx!
Leon
Leon
masuda
- Système d'exploitation : Windows 7 (64-bit)
- Processeur : intel i5
- Mémoire RAM : 6G
Re: PhotoFiltre 6.5.0 with Windows 7 64 bit
Hello,
I have been using PhotoFiltre for last 5 years, and very happy with it. I also recommend all my friends for PhotoFiltre.
However recently I got new PC with Windows7 (64-Bit) using Microsoft IME for Japanese Text. I installed PhotoFiltre version 6.5.0 and start using it, and I realized Japanese text conversion stopped working in PhotoFiltre (I was using Japanese text last 5 years in PhotoFiltre with Windows XP). Now all displying is "..."
Please make this to be fixed for the future build.
Thanks,
Satoshi
Thanks,
Satoshi
==> can you post some screenshot to understand
leontb
Hi Antonio,
how can I post them?
leontb
8 days later, my question is still the same: how can I post screenshots, Antonio?
Taobert
- Version de PhotoFiltre : Studio 10.10.1
- Système d'exploitation : Linux - Lubuntu 14.04
- Processeur : Intel Celeron 2,66GHz
- Mémoire RAM : 1,24 Go
how can I post them? > see here
leontb
Merci Bertrand!
The first link does not work, I think it is more easy to post here the link to the site:
http://www.gevangenispastor.nl
Example of an image made up with PF in XP: Look at the image near the message 'Vreemdeling in de mist'.
Example of an image made up with PF in Windows 7: Look at the image near the message 'Dirk schrijft verder'.
This is what I mean: the difference in rounding edges.
Best regards,
Leon
Best regards,
Leon
the problem is not XP/Windows 7 but PhotoFiltre 6 for the first and PhotoFiltre Studio for the second
Taobert
Graag gedaan!leontb a écrit :Merci Bertrand!
leontb
Hi Antonio,
I have PF 6.5.0, so not PF Studio!
i use windows 7 too and have not this bug, perhaps only with the 64 bits ? if some users wuth 64 bits can reply ?
Hi,
it seems to me that the difference provides from the version used :
don't remember why i changed this value...
Postscripter
- Version de PhotoFiltre : 6.2.7
- Système d'exploitation : WinXP
- Mémoire RAM : 2GB
Seems to get better. But it would be even better to make this parameter adjustable!
This parameter is adjustable in the Studio release.
