Why is "Hide Selection" a menu command instead of ...
Silversleeves
Version de PhotoFiltre : Studio X 10.2.0
Système d'exploitation : Windows XP SP3
Processeur : Intel vPro Dual 1.8G
Mémoire RAM : 1 GB
Message par Silversleeves »
...a dynamic mouse-click result like it is in virtually every other graphics editing application I use/have used in the past/will use in the future?
I understand the usefulness of a "Show Selection" -- even GIMP 2.6 has that on all platforms -- but it sometimes gets me scratching my head why I can't just 'click out in deadspace' to hide or even eliminate a selection. Seldom do I find the "Hide Selection" or Ctrl-D key combination truly useful. I'd like to know what the reasoning behind it was: maybe then I can glom on to its usefulness.
BZT
[zedspeak-glossary]click out in deadspace: to right-click in the same image window outside the bounds of a selection, or somewhere still on the working canvas of the frontmost window not contingent on the selection.
Re: Why is "Hide Selection" a menu command instead of ...
because i don't like this method :wink:
elle
Message par elle »
A user of many graphic programs, I did not recognize this description for what it was...Select None...might more clear.
Silversleeves
Mémoire RAM : 1 GB
elle a écrit :A user of many graphic programs, I did not recognize this description for what it was...Select None...might more clear.
Yes, I agree. "Select None" might be better for future versions of PF/PFS.
BZT
Sorry, don't understand difference between Hide selection and Selection None ?
And in PhotoFiltre, Hide selection is better because you can show the selection again just after, the selection is not lost or reset, just hideen ! :wink:
