Advanced Paintbrush Tool extra brushes
kiwichick
- Version de PhotoFiltre : PhotoFiltre 6.4.0
- Système d'exploitation : Windows 7 Home Premium 64-bit
Hi there, I have been using PF for years and I think it rocks!!!!! One thing I have never been able to figure out is how to use Nozzles and how to access extra brushes in the Advanced Paintbrush Tool. I have put extra brushes in the PF Brushes folder but they don't show in the program. Am I missing something? Thanks for any help.
Re: Advanced Paintbrush Tool extra brushes
Hi,
It is not possible to add some nozzles and brushes in the freeware version,
these tools are only available in the Studio shareware release : http://www.photofiltre-studio.com/
But you can use the Clone stamp tool in Pattern mode to feature something rather near.
kiwichick
Hi Tom, Thanks for that. Sorry I didn't realise it wasn't a free version feature. Why does the add-ons page say they are:
"Add-ones for PhotoFiltre Studio and PhotoFiltre V6"
if they aren't? Very confusing. And when you say:
"It is not possible to add some nozzles and brushes"
what do you mean by "some"? I can add some but not others? Or do you mean it's not possible to add "any"?
And, no, I don't have pattern mode available with the clone tool. The checkbox is greyed out.
=> Yes you're right
it's not possible to add any brushes in the freeware version.
=> Indeed, the checkbox is greyed out when a pattern is not defined : Select a picture or a part of it and go to menu Edit / Define pattern
=> Yes you're right
