cropping
songshine7
Version de PhotoFiltre : 6.5.0
Système d'exploitation : internet explorer
Processeur : ?
Mémoire RAM : ?
cropping
Message par songshine7 »
Hi, I'm new here. I can't crop any of my pictures. The word "Crop" in not in bold, therefore I can't click on it. The words "Automatic crop" are in bold, but when I click on them, I get the message, "Impossible to detect the edges!"
?? I don't understand this. Cropping is one of the main things I need to do. Can anyone help me?
Thank you,
songshine7
Re: cropping
Hi,
which size of edge wish you crop ?
songshine7
Processeur : ?
Mémoire RAM : ?
Re: cropping
Hi Tom,
Thank you for answering.
I want to be able to change the location of all 4 edges on any picture. This is a common thing to do and I've never experienced difficulty doing it in any other photo editor.
I hope you can help me!
songshine7
Re: cropping
Fine,
did you tried to draw a selection form to indicate where are the edges of your crop ?
ptinning4
Processeur : DuoCore
Mémoire RAM : 2GB
Re: cropping
Message par ptinning4 »
Hi I am trying to do this same thing and am new to this. So what do you do after you select the size of the image in order to crop the corners?
Patrick
Re: cropping
Hi, :)
for explore : a little right click into the selection ?
You can also change the form of the selection : Set shape
But mind : a picture is always rectangular, :wink:
if you want to do rounded corners, you must do transparency at the end of your work,
or keep an other color background.
